Which one should I buy, moneys not an object.
The Crucial is around 65 more.
Thanks, Dan
Crucial Technology Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory
Capacity 2GB (2 x 1GB)
Speed DDR2 800 (PC2 6400)
Cas Latency 4
Timing 4-4-4-12
Voltage 2.2V
ECC No
Registered/Unbuffered Unbuffered
Heat Spreader Yes
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory
Cas Latency 5
Timing 5-5-5-12
Voltage 1.9V
ECC No
Heat Spreader Yes
Thanks, Dan
Cas Latency 4
Timing 4-4-4-12
Voltage 2.2V
ECC No
Heat Spreader Yes
Cas Latency 5
Timing 5-5-5-12
Voltage 1.9V
ECC No
Heat Spreader Yes
