OT- Can't believe you blocked Silver Surfer. He's one of the most knowledgeable WC guys there is.
Be that as it may, and I've no idea about that as I've just arrived, I can do without the derision, disdain and disgust; if that's the price of the advice he could potentially offer me, I'm not buying. Part of the reason I like these kinds of forums is for the social interaction, by way of discussion, and the vibe I'm getting from him is decidedly anti-social. Who knows, maybe he just doesn't like me for some reason; he stated he doesn't think I should have posted, but either way I can do without it.
But now that's out of the way...
I wouldn't add anything onto the AIO you're using now until you change that pump out. It is most definitely the weak link.
I know; that's something I'm really going back and forth on. I'm thinking that upgrading the existing radiator to one X-flow, that has a lower restriction than the current radiator, should be fine, and running it through the MB chipset radiator in addition, should probably be okay? ...but to run it through a second x-flow would mean more restriction, and I'd need to mount it to the inside of my side panel, which would require another meter of tubing with a greater weight of fluid, plus some vertical stretches of tubing.
Also, I want to get a fan on the electronics around the CPU socket, and the size of the Eisbaer is preventing me from doing that. If I buy a stronger pump I can put some 90 degree fittings on the CPU block which would help in that, as it would get the tubing out of the way.
It's going to turn out a little more expensive than I was anticipating but I guess watercooling was never going to be cheap. :/
If you were running into stuttering issues it could a few things. You were maxed out on VRAM as ED already pointed too, throttling because your temps were high, drivers needed to be updated and or yes it's possible, your system RAM was maxed but that rarely happens as most have more than enough. It's usually hitting max VRAM capacity. I use a GTX 780 Classified Hydro Copper with 3 GB of VRAM. Let's just say, before i got my 1440p 144hz screen, I was using a 1080p 60hz screen which would hit VRAM cap on some AAA titles with some of the bell's and whistles.
I agree that you should probably upgrade your GPU but what is your resolution and hz you're gaming on? Not sure if I missed that or not. Your CPU and everything else seems fine. Better yet, give us a run down list of your PC with more info on your gaming screen.
Sorry, I forgot to include that: I'm on a 1080p panel at 60Hz. My next panel upgrade I'm hoping to move to a monitor that supports nVidia 3D, although I've not looked at those for some time so I'm not sure what the market for those is like now.
It could be the RAM that's holding me back as it does seem to hover at around 3.5 gig usage; I was assuming that it would have used all of the RAM if it were bottoming out but I guess it might just be avoiding use of the slower RAM entirely?
Re. the performance issues, to be honest I had actually posted at the FO4 forums to try and resolve those and it turned out to be a bit of a mystery. One of the problems I was having is I can't seem to get 100% utilisation of the GPU, it just hovers at around 70 to 80%. The best information I could find, or that people could give me, was that the CPU was the bottleneck. While I was looking for a solution I also found out that
Fallout 4 was one of the very few games that actually benefited from higher RAM speeds, so I took the plunge and bought a new motherboard and faster RAM so that I could build a dedicated gaming PC with better overclocking potential. Shortly after that I bought the Eisbaer and that's what's brought me here...
...overclocking and the faster system RAM did help a lot in smoothing out the performance, but I'm still not getting 100% on the GPU. I've no idea why, although the more I think about it the more I think it could very well be because of the 3.5 fast VRAM limit.
I'm reluctant to post my specs as I don't want to send you guys on a wild goose chase, which I think trying to troubleshoot my system would probably be, but here they are...
Mobo: MSI Z97 MPOWER MAX AC
CPU: i7 4790k
RAM: Klevv Genuine 2x8GB 2666MHz DDR3
Storage: Samsung 950 PRO M.2
PSU: EVGA SuperNOVA 850 T2
GPU: Gigabyte GTX 970 G1 Gaming
Display: 1080p 60Hz
I can get the GPU to 100% in Unigine Valley, and I've got a closed loop water cooler on the GPU, so I don't think temps are the problem? FO4 is a notoriously poorly optimised game however, so it may just be that.
As for what wrinkle in my system is stopping me from getting the GPU to maximum, if I had to guess, I'd have to say it's the GPU and the V-RAM, because everything else seems okay.
Either that or I just maybe need DDR4 RAM and a faster processor, but having said that, none of my current hardware seems to be maxing out while running the game; although getting a read on the CPU has been tricky because FO4 doesn't use all cores and there was an issue around the Performance tab of Windows Task Manager not showing overclocks or boost speeds. Half the people posting about it complained CPU boost wasn't showing up and half were complaining they were getting readings in excess of 100%
because of CPU boost, so...the whole thing is a confusing mess. I did end up using a dedicated monitoring tool developed for Fallout and it just gave me similar results to those I got from Task Manager.
But yeah, for the moment I'm going to run the system as it is and see how things go with Fallout 76, but I'm almost definitely going to swap the pump out when I finally get around to upgrading the loop.
P.S. I know at this point this thread is more or less completely off topic but I personally don't mind, because it's helping me think my way around this problem. I'm just not sure there's a finite/optimal solution to this problem, and I feel like I've hit the point of diminishing returns trying to chase down a solution to this and I don't want drag you guys down this particular rabbit hole with me. :/
Maybe a better way of going about this would be to go the route that's becoming more common on more general P.C. enthusiast sites, where people just post saying "This is my budget, build me a rig" and then all of the forum members set about discussing the ideal build for the given budget.
