- Jan 6, 2016
2 of these: https://shop.ekwb.co...plexi-incl-pump
This one: https://shop.ekwb.co...wm-incl-2x-pump
Or 2 of these: http://shop.aquacomp...roducts_id=3379
Only issue I can see with Aquastream, is this: Permitted coolants: DP Ultra, alternatively water with max. 30 % glycol
So not sure if that means Mayhems X1 works with it.
I will be using an Aquaero 6 PRO to control whatever pumps I get.
And the issue with that is that the Aqua Computer forum claims that EK's PWM dont work properly with Aquaero.
So I'm a bit confused as to what setup works with what.
And in terms of head pressure needs, so will I be using up to 10 blocks and 4x 480mm radiators.
