satandole666 said:
The 4000+ will keep you happy for a little while at 2.8ghz but...
Spend the extra $90 and get a Opty 170. Your mobo should be fine with the 10x multiplier.
I went from a single core clocked at 2.6 to a dual core at 1.8 stock and the difference is AMAZING. Factor in 2.7ghz right now and I can't say that I would've made any other choice.
And remember...a dual core at less than 2.8 will be better than a single core at 2.8 or higher.
Spend the extra $$$ and get an intro level dual core. If you "really" want 2.8 get the 170...if not...get the 165.
IF, I were going to use this CPU for anything other than dedicated use in my HTPC, I definitely would go for a dual core and regardless of its likelihood of reaching 2.8. I would spend the extra money on the 165 and be happy with the increased performance over a single core.
However, to upgrade my existing single core CPU that's already reaching 2.35 MHz would not be worth it to me IF the new CPU would not likely reach at least 2.8. That just would not be enough of an upgrade to justify the expense of a new CPU. And, that the 4000+ San Diego is under $80 and seems very likely to reach 2.8, looks like it would be a win-win for me. I would get a very good chance of 2.8 CPU and for less money than a dual core opty.
I'm looking at it this way. A dual core opty would cost more money, be less likely to reach 2.8 with my current system, and likely would not perform noticeably better than a 4000+ San Diego at 2.8 with a HTPC.
And, an opty 170 for over $109 more than a 4000+... could the performance difference with a HTPC between a 170 and a 4000+ possibly be worth that additional expense?
I mean, is a dual core opty at over twice the cost of a 4000+ going to give me twice the performance of a 4000+ with my HTPC? If so, I'm there. However, I'm thinking the performance difference between the two will be very minimal, especially since I'm only going to use this CPU for my HTPC.
Am I missing something here?
