- Jul 5, 2008
- CFL
I have read that this type of dual-fan stock GPU cooler pictured below:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121705
Can actually raise the temperature inside a PC case than a centrifugal style fan GPU cooler like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161399
Is that true? I believe this is true since it appears that the centrifugal fan directs the warm air out of the case, while the dual fan just blows the warm air towards the top of the case (in a typical PC setup) resulting in slightly increased ambient temperatures, specifically around the CPU/VRM area. Would anyone agree with this? Has there been actual tests to prove this?
Now if the dual-fan setup is known to increase temps, especially when overclocking, is it worth having the dual-fan cooling setup over the centrifugal style cooling as far as mild overclocking is concerned? I'm sure the answer to this is yes, but I wanted your guy's input on this.
My goal is to buy a GPU (7970 or 680) in which I can perform a mild overclock while keeping ambient temps as low as possible.
