- May 15, 2010
- Euroland, Denmark
I have been messing around with my 4770K rig, and for once gotten down to the finer points of my loop.
The setup is made to silent, but i am starting to dear, there is not enough rad for the long run.
Setup is: (Is all on order of how it is connected)
D5 Pump/res
EK 240mm, 50mm thick (Push/pull GT AP15's)
EK CPU block
Magicool 360mm, 30mm thick (Pull GT AP15's)
EK Universal GPU
EK Universal GPU
back to pump.
After many hours of use, i can leave it to idle (30mins), and the water temp inside the loop will fall to around 37degrees. During gaming it will get into the high 40's (Intake air during all this testing: 23/25degrees)
When gaming for many hours, i see my CPU hit around 80degrees on my CPU, and 60/65 on my GPU's maybe up to 70 in the second card.
This is after my mind, acceptable, and i can live with it, but i would like to bring down temps, without setting up the speed on the fans.
I will admit i run very low speeds, 300rpm when temps on CPU are below 45, and then they speed up from there, being 100% flat out if the CPU hits 85 degrees.
I want to bring down the temps on the water in my loop, I am confident that more rad surface could help this issue, but i am not sure what would be my best option?
The 240mm sits in front, and the 360 sits at the top. I have 1x GT AP15, as a rear exhaust fan.
Picture for better idea:
The options that I have come up with fro now.
I have (with a shoehorn) the space to replace the 240mm EK with Alphacool NexXxoS Monsta 240, which is 80mm thick, and still retain my push/pull.
OR
I could get a 120mm rad, slim version, and mount its on the outside of the case, (where i have the exhaust fan mounted atm) and then bring the fan inside, to push.
I am pretty sure that going for the 80mm thick rad, which would 30mm more than i have now, would equal 2x30mm.
What do the pros have to say about this?
D5 Pump/res
EK CPU block
EK Universal GPU
EK Universal GPU
back to pump.
OR
