- Jul 26, 2004
Just like the title states PPl seam to be getting very nice OCs with these new brisbane's but when ever I see the Pi times im like hmm that doesnt seam right my 939 @ lower clocks is beating it . why is this ?
||Console|| said:I get that about the timings but ddr2 is running @ a higher freq so the higher timmigns shouldnt matter that much , afaik
i dont know if that is right or not I have never used a AM2, but i have seen bw tests in Sandra and the ddr2 always has more bw than the ddr1 .ryboto said:But DDR2 also runs at a 2T command rate, right? That will make a pretty big dent in overall bandwidth.
I hope sosplat said:I think that since the jump to AM2 was primarily only to add support for DDR2, they didn't really make any significant changes to a) the processors and b) the motherboards. I think that when AMD finally has an architecture change, you will start to see those times drop to rival the sub 10s times at the top of the Intel rankings.
funnyperson1 said:Latency is very different from bandwith, latency measures how fast data can move from one place to another whereas bandwith measures how much.
Latency would be how long it takes you to get from A to B on a specified road, while bandwith is concerned with how many cars you can fit on said road. You can't really compensate latency with bandwith because they are two entirely different things.
Can I see some links please Woudl liek to check the difference with there sub timmings vs some others .CCUABIDExORxDIE said:tweaking ddr2 is also very hard as well to get low latency. and most people who are benching spi with these 3600+'s, for lack of better words, arent benchers. they are average everyday ocer's who dont know how to optimize like you or others do.
ive seen some times from a sempron am2 that would make your 4400+ blush, its all about tweaking.
console you have to remember, you have 1meg L2 cache vs 512KB on the Brisbane. Also the move to DDR2 cause a bit more latency to the cpu cache. Also super-PI loves tight timmings.||Console|| said:Can I see some links please Woudl liek to check the difference with there sub timmings vs some others .
my best time on my 4400+ is 28.4 I think that was @ 2.95ghz
seems alot better then s939
