Exactly.$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Solid state capacitors are more than 10x the cost of electrolytic capacitors (See Silver's pictures).
Multiply that by 10-20 per GPU and 50+ per motherboard, that cuts cost fast.
Its not "being cheap", its "not making a motherboard cost $700".
You mostly find electrolytic caps in "rock bottom ronnie" segment and OEM motherboards, as well as audio applications these days. The days of buying a midrange board and seeing it coated in electrolytic caps are over.
Yes, don't use stolen recipes!Can electrolytic caps be made as reliable as tantalum caps? I remember reading an article (maybe posted by ED) that suggested the huge number of electrolytic cap failures in the early 21st century were due to Taiwanese based industrial espionage that failed to properly copy the complete formula for some revolutionary Japanese electrolyte formula.
My board has all Japanese Solid Capacitors.
Actually, I've read that tantalum caps can explode.
Wanna see what happens when a cap explodes while you're baking a vid card?
Wet tantalum caps are electrolytics. Even solid polymer caps, whether tantalum or aluminum, are electrolytics, according to the company that invented them: "Low ESR obtained by using conductive polymer electrolyte."Can electrolytic caps be made as reliable as tantalum caps? I remember reading an article (maybe posted by ED) that suggested the huge number of electrolytic cap failures in the early 21st century were due to Taiwanese based industrial espionage that failed to properly copy the complete formula for some revolutionary Japanese electrolyte formula.
Card was only in for 4 minutes @ 375f.huh..
Bucket list
✓ "Watch GPU explode in oven"
Too hot?
I was under the assumption that those solid caps won't explode?
EDIT:
I think you may have overbaked that card a little.
