- Jul 7, 2013
from what i'm told, it reduces clock speed to prevent high temps. with just CPUID HWMonitor and 4 firefox tabs open my Phenom X4 9850 BE is running at 48 degrees celsius. maybe it's normal for this old of a chip, but that seems a bit warmer than what it should be. heat is already an issue, a 5% overclock jacks boot temps up to 50 degrees celsius (5% being an increase from stock 2.5GHz to 2.6GHz roughly) so should i disable it or not? by the way i don't know if my CPU cooler is stock or not, after ordering this new motherboard so i could overclock i had a shop put it together and before that i bought the PC used at some other shop. so cooler is unknown. anyway if someone could clarify the whole cool and quiet thing it would really help.
