939 has twice the max memory bandwidth of a 754 due to the 128-bit memory bus in 939. This is in additon to the dual channel memory controller in 939. For applications that require constantly changing, large, and well structured spatial data as in scientific computations, video encoding/decoding, image processing, ..., these applications would be benefited directly from the 128-bit memory bus of 939 (vs the 64-bit of 754), .... Since data needs to be refreshed constantly from the main memory (L3) to the on chip L2 via the memory bus as size of data >> L2 size at any given time.
Interesting question: how would the following A64 perform running the same CPU frequency, memory bus frequency and HT bus frequency
A - A64 1 MB L2, 128-bit memory bus (939/940)
B - A64 1 MB L2, 64-bit memory bus (754)
C - A64 512 KB L2, 128-bit memory bus (939)
D - A64 512 KB L2, 64-bit memory bus (754)
A is better than B or C.
B or C is better than D.
Between B and C, it depends on applications. For memory intensive applications, C has an advantage.
(My choice would be C (512 KB L2 939) at first to save money on CPU, then upgrade later to A (1MB L2 939) when CPU yield mature and price lowered.)
Recap on 939 memory latency, memory bus bandwidth and system bus bandwidth:
For the A64 CPU, the memory traffic and the traffic for the rest of the devices (video, IDE, SATA, serial links, ...) are separated at the CPU rather than at the chipset (NB). As a result,
- The average memory latency between the CPU (after L2 miss) and the memory (L3) is reduced.
- The effective bandwidth of the A64 memory bus (128-bit in 939) to/from the CPU is alone higher than the effective P4 memory (and system) bandwidth (estimated about 15-20% higher), and almost twice that of XP and also that of 754 (estimated 81-89% higher).
(See earlier post on memory bandwidth.)
- The max combined system bus bandwidth of memory bus (in 939) and HyperTransport in an A64 system is more than twice the sytem bus (FSB) of a P4 system and four times the system bus (FSB) of an XP system.
(See earlier post on system bus bandwidth.)
