- May 10, 2009
So, it's (constantly, and correctly) said that you should not open computer power supplies due to high voltage.
Being bored, I decided to do two things:
1) Play with high voltage.
2) Explain a bit more.
3) Make a video.
First up is the explanation! There are three main sections to a PSU that contain capacitors that can hold a charge after the unit is turned off and unplugged.
You really shouldn't open a unit that is plugged in, there will by live mains voltage inside, and it has a good chance of killing you if you touch the wrong thing.
In order:
1) The transient filter, this is charge to line voltage (peak) at most, and has fairly minimal capacitance. Worst case, it hurts. You'll probably live. It comes with a discharge circuit that should render it safe within a few minutes.
2) The APFC section and storage capacitor. Usually has a discharge circuit of some sort, as well as bleeding out to an extent powering the 5vSB circuit while unplugged. It is charged to ~380v during operation and has a significant amount of capacitance. It takes a significant amount of time to bleed out under the best of circumstances (minutes), and takes a very long time in some designs. We're talking days, in theory. (Older passive PFC and non-PFC units may hold it even longer)
3) The output side, which has a lot of capacitance, but is only charge to 12v/5v/5v/3.3v/-12v. You aren't going to do anything meaningful to yourself with this. The 12v will drain out rapidly through the fan, anyway.
#1 isn't overly much of an issue. #3 isn't one at all.
#2 on the other hand can do real damage.
I built a circuit to charge a small (330uf) APFC capacitor, charged it to ~75v and discharged it via an alligator clip.
Note the alligator clip welding itself to the lead it touches! Not subtle, this.
It's far from the most impressive youtube capacitor discharge clip, but keep in mind that in service the voltage (and hence, energy) is about five times higher.
The circuit is simple, but I am not going to share it as you can do Bad Things to yourself with it if you're not careful.
If you don't know how to build it, the odds are good you shouldn't
3) Make a video.
In order:
