For nforce2 AMD MB, when the dual channel memory is running at the SAME speed as the FSB (aka SYNC mode), there is little benefit in terms of improving the system memory BW. Since the FSB BW cannot absorb/supply twice the BW supplied from/to the dual channel memory when the two are running at same frequency.
For AMD MB, the max system memory BW is FSB x 2 x 8 = 16 FSB MB/s, e.g. FSB = 200 MHz, maxBW = 3200 MB/s, actualBW ~ 3050 MB/s due to some overhead.
You may even be better off just using one module since there is a better chance to get a few MHz of the FSB higher and tigher memory timing. The different between single or dual channel at SYNC mode is only 1-2 % of memory BW.
In my opinion, for AMD nforce2 MB, running dual channel with expensive, matching pair at SYNC speed is wasting the most expensive, top HALF of the memory BW, you won't be able to get that part of the bandwith at all.
BUT on the other hand, if FSB is much higher than memory speed, in the case you use old, cheaper memory, there is a benefit of running dual channel ASYNC mode. Intel chipset has been running memory like this.
E.g. FSB = 200 MHz, PC2400 memory running at 75% ASYNC. The resulting system memory BW will be like running PC2700-2800. 3D mark will show such benefit.
