Bad Maniac said:I would love to se some numbers to support this. I was just about to post that a single rad is plenty for a stock or slightly overclocked system, and will give you better cooling than air. Dual rad if you intend to do heavy overclocking with CPU and dual GPU's.
Running two MCP655s isn't a bad idea but I only do it for the redundancy factor. If you don't need or want that then one pump will be plenty. As you can see in my sig I run both of mine at ~1/2 speed - as a side effect it also reduces pump noise ...Trike007 said:Very true.
As for the pump, I plan on running at least 2 maybe 3 single 120's IF i decide to go water. So the 655 would be perfect and with the added single radiators. I will probably go with two pumps in series instead of one.
I'm also tempted to buy another chip.
[edited quote for shortness]wombat778 said:According to Swiftech's charts / a MCR120 can probably dissipate about 130-140 watts /
According to the PSU calculator / an E6600 overclocked to 3.6 at 1.5 volts puts out about 140 watts.
Therefore, I would think that a single MCR120 would be insufficient or barely sufficient to handle the heatload produced by the E6600 at the speeds and voltages Trike wants to run at.
Bad Maniac said:[edited quote for shortness]
Still you can cool it enough with a regular heatsink and that same fan? Give me a break, those swiftech numbers are complete nonsense.
Easy, Look at air cooling. Mid range air is plenty for stock or mid range overclock. The average single rad has more total surface area than an average mid range heatsink yes? Mid range air has a 70-80mm fan yes? Good, water is hundreds of times better at carrying heat than air yes? So, better heat carrying capacity and more surface area than mid range air, and mid range air is plenty, so a single rad is more than plenty.wombat778 said:May I now return the favor and ask you for numbers to back up your statement that a single 120mm rad is "plenty?"
