Arggghhh!!!!!
Having some trouble with my sig '3dv' 3930/RIVF build. Been running without issue for a year or so until the last few days.
Restored a known, good image and started setting up some games. The mouse kept freezing (losing power for a sec) in Skyrim with widescreen fixer enabled. Tried L4D2 (another steam game) and it did the same thing. Deleted steam, re-booted, re-installed steam and no mouse issues in L4D2. Started widescreen fixer and skyrim, mouse issues. Skyrim without widescreen fixer and no mouse issues (too bad it's not really playable without the fix).
Resetting bios settings to default, non-overclocked didn't change anything.
Dug around a bit...seems to be nvidia drivers. Read someone had luck with the 326.80 drivers. Did a clean install of the new drivers and re-booted, pc hung at the win splash screen.
Restored the image again, re-booted and logged into windows. No problems. Re-booted, hung at the splash screen.
Did a clean, full install of win 7 x64, no problems. Got into windows with no issues. Installed the older, working drivers and re-boot....stuck again
Thought it was the nvidia drivers but then why wouldn't the older ones work after a fresh formatting and rebuild? Thinking it may be something else since even the 'known good build' only gets me into windows once (as does the fresh build).
Going to try a few more things but wanted to see if anyone had thoughts. Everything's at default settings (except hyperthreading, speedstep and c-states disabled).
tia
Update: Cpu seems fine..3.5GHz at 1.232v (cpu-z)...prime95 with error-checking's been running a while...no errors and max core temp (in hwmonitor) is 56C.
Update: More weirdness. Still sticking at the splash screen from a cold start or re-boot but if I go into bios and 'save settings and reset' it gets right through to the login screen and then desktop.
tia
