- Jan 2, 2008
- The Grey Sky's Of Michigan
Can someone point me to a safe link to download the Win 8 Pro ISO? I have my key bui need to create a boot able ISO disk.
Thanks
Thanks
http://www.neowin.net/news/here-is-how-to-get-the-windows-81-iso-and-create-a-usb-install-stick
Windows 8.1 cannot be initially installed using your official retail Windows 8 key.
Use the following Microsoft-provided key
GCRJD-8NW9H-F2CDX-CCM8D-9D6T9
to initially install Windows 8.1 Professional.
After completing Windows 8.1 installation, change the Microsoft-provided installation key to your own Windows 8 key.
Right click on This PC > Change Product Key
or
Windows 8.1 Control Panel > System and Security > System > Change Product Key
Do so from DOS Command Prompt using command:
slui 3
or
Method 1:
Swipe in from the right edge of the screen, and then tap Search.
Or, if you are using a mouse, point to the lower-right corner of the screen, and then click Search.
In the search box, type Slui.exe 0x3
Tap or click the Slui.exe 0x3 icon
Type your product key in the Windows Activation window, and then click on Activate.
Method 2:
Run the following command at an elevated command prompt:
Cscript.exe %windir%\system32\slmgr.vbs /ipk 1-2-3
(where 1-2-3 is your product key)
Will this method work with OEM Windows 8... I've been looking for a way to do a clean install of OEM Windows 8 on my laptop without having to pay $60 to get the installation discs from Lenovo.
Thanks, c627! ("Bookmark post")
