- Aug 27, 2003
- Mississauga, Ontario
I don't know why Windows does this, and it really gets to me.
In any case, I had to reinstall windows after more then two years (Win 7 Ultimate x64), I had a major crash. Now, with only 1 HDD on the system, it installs everything onto that drive, but when there is a second drive, for some reason it puts the boot folder and record onto another drive.
In my case, now I have my SSD drive with windows, but the boot directory and some files are on one of my storage drives (I have two, I'm not sure if it just chooses one randomly or what).
Why does it do that? This has happened to me before, when my storage drive crashed, I couldn't boot windows anymore even tho windows was installed on a healthy drive. I could fix it, but I forget how, I think it was a command run from the windows disk to make the C drive have the boot record.
In any case, the C drive, the SSD drive, has all the windows files, but my storage drive has the boot directory (hidden system directory), along with "bootmgr" "bootsect.bak" "install.log" "msdia80.dll" files, and I don't want ANYTHING on my storage drives but storage files.
I know that I should have disconnected my two drives when installing windows and just have the SSD connected, but really, why should I have to do that? Is there a reason that windows does this, when it's clear it doesn't have to since it runs just fine with one drive.
So besides wanting to know why, I also want to know if there is a way to transfer those files onto my SSD windows C drive, and change windows to think everything is on C drive rather then have those important files on my storage drive (and they are important, in the past I deleted them thinking it's a mistake and all of a sudden I couldn't boot anymore, thus the above mentioned fix which I found out about).
Thank you for any help you can offer.
