J jd5449 Registered Joined Jul 11, 2003 Location Summit il Aug 8, 2003 #1 i am installing 98 and get almost finished when i get scanning system reg win set requires 7340032 bytes avail. can someone please help
S SinsFeelNatural Member Joined Jan 9, 2003 Location Phx. AZ - USA Aug 8, 2003 #2 What size hard drive are you trying to install Windows 98?
nahmus Member Joined Apr 5, 2002 Location Sailing the Azure seas Aug 8, 2003 #3 It sounds like you might have a virus or something funky going on with you HD. try resetting the MBR by doing the following. fdisk /MBR
