- Sep 3, 2009
Hey everyone. I'm new here obviously. I just got done rebuilding my P182 rig. I upgraded a few things like from a Q9300 to a Q9550, 8800gt to a 9800GTX+, and installed a basic RAID0 configuration.
Before I setup my hardware, I removed everything and did a spray job on it after seeing the P182SE chassis as some do. I'm very happy with my results. I've also fully configured a large array of fans. This rig was originally going to be a Media Center PC for my home theater setup but I have a smaller case and it hosts my older hardware profile and large hard drives. This is going to be my gaming rig but I'm not going so far as to water cool it yet.
So now I have a setup that I'm very happy with. It hosts a basic satin black chassis with Aero Cool Silverlightning fans throughout. I'm currently modding the front doors to remove half of the fins in the fan doors to allow more air flow and also allows the LEDs to shine.
I'm posting here obviously for a window mod how to. I want to hide my HDD bays and I would like the window to run top to bottom showing the upper most fan down to the Mushkin PSU sporting a Silverlightning fan and lower chamber fan. Possibly a 10" by 18" window roughly?
I do know how to search, I've googled a lot in this topic. What I see is end results and no write ups. I know the P180 series cases use the Aluminum / Plastic / Aluminum sides and this makes it difficult to cut through. What are my best options? I have a Dremel... I just don't want terrible edges and I don't want to see the inside of the panel. Is it best to bolt the window on the outside, screw it on inside. I'd rather not tape it on. I'm afraid mounting it inside will show the mess around the edges I cut or something inside.
That's my scenario. Since there's no real newb page or intro page I will just post some specs and pics for you all to get an idea of what I have going on:
Antec P182 Case / Black Chassis
Asus P5Q-E
Intel C2Q Q9550
Thermalright True Black120 Rev.C w/ 120mm Silverlightning CPU Cooler
8Gb Corsair XM2 DDR2-1066 5-5-5-15
500Gb + 500Gb WD Green Power HDD RAID0
EVGA 9800GTX+ Superclocked Edition
Thermalright T-Rad2 w/ 2 92mm Silverlightning GPU Cooler
Muskin 550w Modular PSU
(Pictures show missing top rear 2 120mm chassis fans, PSU fan, front fan doors)
(Missing PSU fan)
Asus P5Q-E
Intel C2Q Q9550
(Missing PSU fan)
