- Apr 19, 2012
I'm having an issue with my AMD set up as seen in sig..... Let me try and explain.
Traditional blue screens are gone. I mean the system still blue screens, but it looks different.
Finally getting time, I installed W10. right from the get go, W10 tries to get internet access for updating or w/e have you there.
My issue that occured was the system was restarting and I had no idea why. this was happening during the set up process after installation.
To the point.
The Formula-z board I'm using has an Intel NIC card built in. W10 actually had a or some driver for it, apparently the same driver that's on my asus disk.
Well it doesn't work. Or doesn't stay working and the Asus Intel driver application says there isn't an Intel NIC card.
OK fine then. Unplug the Ethernet cable and the system works great!! No hangs, no hiccups no blue screen restarts.
Have tried many drivers available for Intel 100 series NIC and nothing but blue screens.
Will try and get to the store today and find a PCI-E NIC card and see if I can have some internet un-interrupted.
Basically I'm not looking for a cure, as I already know what the issue is for me, but thought to share if others have the same issue during installation. Simply unplug your ethernet cable from the NIC card and all should be well..... Or at least this could be an issue for you as well if you have a similar system.
Other than that, W10 seems pretty snappy and quick. Most of all my programs work, overclocking, gaming, and benchmarks and more.
Certainly need some time to better critique W10 as I just installed it a few hours ago.
Hope this help someone along the way, try W10 and enjoy.
Shrimp.
To the point.
Shrimp.
