- Jan 7, 2005
Here's an article describing MS's telemetry data collection.
I don't have Diagtrak file anywhere in my W10 Pro system.
They're part of a larger trend in the software industry to collect and analyze event data
"On a Windows 10 PC, telemetry data is stored in encrypted files in the hidden %ProgramData%\Microsoft\Diagnosis folder. The files and folders in this location are not accessible to normal users and have permissions that make it difficult to snoop in them.
Even if you could look into the contents of those files, there's nothing to see, because the data files are encrypted locally."
The article says its hidden, i don't see it as well on my system but might be there regardless.
If I don't have the Digitrak file in my services then it's academic. No?
The article says its hidden, i don't see it as well on my system but might be there regardless. Either way, Spybot Anti-Beacon SHOULD take care of it, or part of it no ?
Just type %ProgramData%\Microsoft\Diagnosis in an explorer/run menu and you will for sure see the directory. According to what I have seen and read, Windoze 10 Pro is set to "Full" by default. I do not believe this setting can be changed for the professional version, unless it's coming from a GPO.
It has to be there. %ProgramData% is not visibile in general, similar to the %AppData% folder in the user profile.
Just for comparison my diagnosis folder size is 64mb and out of curiosity had zero hits on Digitrak windows search on Google.
"just because I'm paranoid doesn't mean they're not out to get me"
Misunderstand, Digitrak is not there, ..
Eventually updated to Win 10. Everything is ok, except of just 1 thing: it looks like booting process takes more time then before. Are there any reasons for this or any possibilities to check if there are any reasons?
