Do not use anything that calls itself a registry cleaning program though. No such thing exists that does more good than harm.
I Had a problem with CCleaner and windows XP registry I had to do a clean install.Have been using CCleaner and Puran Registry Cleaner for years and they do a very good job ?
"Never have, never will."Have been using CCleaner and Puran Registry Cleaner for years and they do a very good job ?
Personally I don't trust any third-party registry cleaning programs, especially from unknown sources, for determining that my registry has errors that need to be repaired or deleted. If you were to do a registry scan w/ ten different so-called registry cleaning / repair programs, you'd get ten different scan results. So being that the results would be different based on the program, which one would you trust to clean your registry?
A guy posted here some time ago that used the built-in registry cleaner in CCleaner, after which on reboot Windows refused to load either to normal mode or safe mode. He hadn't made a backup beforehand, and had important data on the drive that he couldn't afford to lose.
If 'optimizers' are not snake oil then what do they remove from registry that measurably improves performance? What were the symptoms of broken PCs, what did they do/not do after being repaired by programs which removed registry entries?
Wow....thanks for sharing! Can't say I had that much trouble.
For computer management, just right click on Explorer or this pc and then manage. That shortcut hasn't changed.
Doesn't task manager always pop up on the main screen? It's been a while so I don't recall.
W10 is much more secure than 7, actually. If you don't want to click no.
No memory leaks in 10. I don't recall it using more memory... at least nowhere near that much anyway.
Always a pleasure to see someone post what they specifically don't like, maybe it can be enabled/fixed rather than endless complaining about default settings of Windows 10.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp
C:\Users\[your user name]\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
-Overall UI seems unintuitive. A lot of flash, but maybe a little light on the functionality side of things. I don't think I'd install this on a PC for an aunt, uncle, grandmother, or grandfather (or anyone in or near the senior citizen crowd). My older relatives are confused and frustrated enough by Windows 7 and 8/8.1, I don't need to add further confusion.
YES. All that can and should be manually removed. Install this and make your own heaven UI.
http://www.classicshell.net/downloads/
-Can't seem to set all of my screens to the same wallpaper, while using the slideshow feature with the wallpapers (I have multiple wallpapers that I normally set to change every X number of minutes). So, each screen has a different wallpaper. This might be useful if I had multiple views of one scene I wanted to display across my monitors, but I don't, so it isn't really useful so much as it is annoying.
That is what I do. You can do too if you buy this program http://www.displayfusion.com
-WAY too many security risks. Connecting to the same wifi as users on my contact list? Why would it assume that because someone on my contact list is connected to a wifi, that then that wifi is automatically safe and secure enough for my computer to connect to it as well? Automatically connect to nearby wifi hotspots? Uh, no thanks, I think I'll choose which wifi connections to connect to. Use my computer to send and receive updates to and from other computers? Uh, no thanks, that sounds like a security risk and I don't want my computer running as a bot to download updates for other PC's.
-In Windows 10 my PC seems to use a lot more memory, for reasons unknown. At idle sitting at the desktop in Windows 7 I typically used 9-15% of my system memory. At idle sitting at the desktop in Windows 10 I am using 25-28% of my memory, for reasons unknown, as a quick stroll through Task Manager doesn't reveal any programs or processes that are using an unusually high amount of memory. Some kind of memory leak maybe???
Yes. You need a list of things that need to be changed. Things you listed can be changed. Ask how if you don't know any specific one. RAM is allocated for your benefit and released as needed. Not necessarily a memory leak.
