- Jan 9, 2007
Hi all, hoping for some logical advice as to my problem and I thank you in advance!
I have a PC that I build myself for my mother a good few years ago. It is an AMD Phenom 1, quad core 2.4 GHz with 2Gb of RAM. This is purley a desktop PC so I left the standard HSF which came with the new CPU inside.
System has been running fine for years, I would clean it out every so often as I reused the old chassis / case and it could get dusty inside.
Relatively recently I installed an IP camera and used this PC for recording the camera. CPU usage remains about a 5 to 10% usage on average and the machine is left on 24x7 for recording purposes. A few days before I was due to leave the country I noticed the fan acting noisily. I didn't put two and two together until we got a couple of blue screens and I attributed the fan noise to over heating. I cleared the dust out and the small amount of dust which seemed to be restricting airflow around the HSF. Immediately after power up the fan noise was back to normal. However we kept getting blue screens and reboots.
I decided the OS must have become corrupt so rebuilt from scratch. The same day I had to catch a flight, unluckily for me the blue screens continue.
I have remote access to this machine via VNC via a Cisco VPN. I have checked the event logs both times and they do not say much by way of reporting the issue. They say something along the lines of "system returned" but do not describe why the system went down.
Is there anything else I can run or check on the machine to find out what is causing this?
Or,
Have I killed the machine due to the over heating? The machine is in England and we've just had winter. Ambient temps are around the 20c mark due to central heating.
Also, whilst I vacuumed the dust, I also reseated the RAM and made sure there was also no dust inside there.
Any advice is greatly appreciated!
Or,
