hello folks
I just bought new WD 2TB HDD and installed it today. windows installed the drive with out any issue format and assign a drive letter. then after rebooting the system windows splash screen loads then instead of the desktop I get a black screen with just the mouse cusor and nothing else. cant launch the command prompt etc.
If I boot to safe mode it loads as it should with the HDD and everything working as it should.
If I remove the drive letter the oringal issue occurs but If i delete the drive my normal windows account loads as normal.
they system is running win 7 ultimate 64bit
MOBO Gigabyte GA-990FXA-UD5
amd FX 8120 3.1 GHz
SAPPHIRE Radeon HD 7950 OC 3GB
Corsair CMZ16GX3M4A1600C9 16GB 1600MHz CL9 DDR3 Vengeance Memory
Corsair TX850 Enthusiast Series TX 850W ATX/EPS 80 PLUS Bronze PSU
boot drive: OCZ AGT3-25SAT3-120G Agility 3 120GB SATA III 2.5 inch SSD
2nd HDD: Western Digital 2TB SATA 6Gbps Power Saving Internal Hard Drive OEM - Caviar Green
3RD one that issue started with same as above.
amd FX 8120 3.1 GHz
