- Jul 5, 2008
- CFL
Hi guys. Trying to fix a friend's PC. The PC is an HP Envy 20.
They recently did a factory reset on the PC after a failed attempt to update to WIndows 8.1.
I was not the one who helped them setup the PC again with their username, etc.
The main problem is that Windows Metro generally thinks it is not connected to the internet. However, Google Chrome and IE load webpages just fine. Skype works, etc. MS Store app DOES NOT work. I ran windows updates and according to it is up to date. Last update it installed was a C++ VS 2008 SP1 runtime update.
I have googled this problem extensively and a lot of the advice is from 2012. I followed the advice and still no connectivity to the App Store. I've reset the cache, reset proxy settings, etc.
Another attempt to figure out this problem was when I try to add my MS account. However, I cannot add my MS account because MS Metro thinks it is not connected to the internet - so maybe even Windows update is not connected at all.
Any ideas?
Any ideas?
