Situation:
Uninstalled all nVidia software using Control Panel.
Restarted
Installed nVidia 310.70 WHQL driver.
Restarted
Display works until it reaches what should be the Windows screen. POST displays properly, Windows splash looks normal, but when it tries to go from splash to OS the screen just starts to turn on/off/on/off continuously. NumLock light on the keyboard flashes in cadence with the screen. A soft reset (even leaving the system off for 30 seconds) will result in the screen flash starting right after POST. A hard reset (via the power supply) will get me through the splash screen to the flashing part.
I've tried spamming F8 and SHIFT+F8, but I can't get the boot options screen to come up no matter what. Something obviously went wrong with the driver install, but if I can't get to a desktop/Safe Mode/Recovery/Boot options there isn't a whole lot I can do.
Keyboard does work to get into the BIOS options so I know that it is, in fact, working.
Any ideas?
Restarted
Restarted
Any ideas?
