- Feb 18, 2002
.htm files (not web page link files) started having blank icons and I could not change them using the usual approach of repairing icons, or changing Folder options > File Types TAB > htm > Advanced > Change icons
Even registry changes did not help.
Downloaded this htmliconfix.zip file and it fixed it.
http://windowsxp.mvps.org/htmicon.htm (scroll down)
What did it to, what did it change, I want to reimage and figure this out manually without using the exe file. Any ideas?
EDIT:
This worked in Windows 7
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\FirefoxHTML
Delete the ShellEx\IconHandler registry key entry.
Then I saved this as a Rebuild.bat file then run it. Then Reboot.
taskkill /im explorer.exe /f
CD %USERPROFILE%\AppData\Local
attrib -h iconcache.db
del iconcache.db
explorer.exe
EDIT:
del iconcache.db
explorer.exe
