- Jan 12, 2003
So I havent tried this in a while for various reasons, but here is something that works well in cold winter climates.
While I was in college (and not paying the heating bill), I had an AMD K6-III 400 that was a pretty stubborn chip. It would do 450 OK, but nothing much more. During the time after I broke up with my 1st girlfriend, as you can imagine, I had a lot of free time and worked on my computer a lot. Hell, now that I think about it, breaking up with my girlfriends (or more appropriately, being dumped) probably got me a lot of the computer knowledge that I use today... but that's another story.
I was attending college in Connecticut and it was a particularly cold winter. I was bored one day, so I got out my drill and some tin snips and began cutting. I cut out an 80mm hole in the side of my case.
I then attached a 120V 80mm fan that I ripped out of an old 286 switching p/s (found in the lot of computers being trashed by the physics department). I was too lazy to find screws or anything, so I used some silicone II sealant from another project to attach the fan. It actually worked pretty well, and isolated the vibration from the 2" thick fan. The fan just had bare wire leads, so I shoved them in the end of a spare computer power cable that I plugged into the wall (probably not the smartest thing to do!)
After rummaging around for a bit, I ended up in the laundry room, and ripped off some ducting from one of the dryers... not like they would miss it. I shoved the ducting over the fan as best I could (it took some force) and then put the other end out the window.
After plugging the rest of teh window with carboard and shielding the "intake" from the sun, I was ready to fire it up. Voila! instant 500mhz K6-III running around 3C @2.4VCORE!
Unfortunately, I dont have any pics of the rig, but here are the screenshots from Mobo Monitor and WCPUID.
http://efisher.web.wesleyan.edu/Pics/500.jpg
http://efisher.web.wesleyan.edu/Pics/500WCPUID.jpg
Cheers!
PS. If your happen to look at the other pics, please dont judge be based on them! hehe
Cheers!
