- Dec 31, 2004
- San Antonio Texas
There appears to be a conflict between the mobile barton 2500+ sticky and the pin mod at http://tinyurl.com/f504 There at ocinside, selecting "socket view", and "Unlock via bios up to 12,5x" show a very similar, but not exact match for that single jumper to boost the multiplier. Neither worked on my A7M266-D rev 1.04 asus. With no jumper I am booting into 800 mhz per cpu and use crystalcpuid to set the speed to 2000mhz (15x) as that is the maximum. I assumed (google shows) that 2000mhz is the actual speed rating for a 2600+ mobile but I cant find a reference at AMD site to verify.
I attempted the wire trick listed at the sticky here under CPU-AMD and discovered that my A7M266-D boots into 14x multiplier = 1866 mhz. At least it did something. It is still limited to 15x multiplier (2000mhz) by CrystalCPUIDF. It would appear the multipliers above 12.5 cannot be enabled using that wire mod on the mobiles I just bought. I also tried the wire trick as listed at ocinside but could not boot with two cpu's. One cpu booted, but came up at 800mhz and was still limited to 15x multiplier.
This motherboard, or at least the version I have, cannot set the FSB above 133 so I can only play with the multipliers. Do I have one of those locked cpu's even though mine is mobile?
