- Dec 31, 2004
- Osan AB, South Korea
Check it out. 3GHz (2.8something stable) on an X2 4800 with a DFI board and an XP-90C at 1.6vcore and around 40C. Not bad at all, especially for 2 cores under one HSF!
Dual core? Then it aint the same thing.People on FX55s have been doing that much since last year
Sentential said:Honestally. Im sure people can do 3ghz suicide shots right now on air. Unless its actually stable Im really not too impressed
2.8 on air is nothing. People on FX55s have been doing that much since last year
Quailane said:Dude, you should be banned from the amd forum.
chris64 said:yea good stuff, im gonna start saving now, 500 buks is a lot!!!
Spion said:the 4200+ is around $500. the 4800+ is around $1000
Same aproximate die size and technique. What would make you think that a core with the same design and die size WOULDNT clock as well as an FX55? Seriously. What makes this so special when dozens of people have done the same thing? Its nothing more than a binned FX-type chip, nothing special.WingsofGOD said:Dual core? Then it aint the same thing.
I think it is really impressive running dual 2.8Ghz athlon 64's. Each one of those processors by themselves is going to beat all but supercooled pentium 4's. When comparing the dual core amd to the dual core pentium, the intel chip is left in the dust because it can't overclock very well. Each of these athlon 64 cores is hitting the max overclock of what a single core can do. This means there is no trade-off performance wise by going with amd dual core. If you get the dual core intel chip, you will be beat at playing games and encoding by the single core processors, but only take the advantage when running multiple power hungry apps.
Thankyou very much. Here is where I am taking my opinion from. This here is a graph created by AMD that shows power/max frequency. Ie true yeild rates. Take a look.deception`` said:I don't really think this sort of behavior is necessary. While I agree that the overclock is nice, the fact of the matter is that there is not enough information on these cores for us to assume that this is a realistic result. Having said this, you should recognize that what Sentential said actuality had a hint of reality in it, as the masses need not be swayed by simply one review.
deception``
WingsofGOD said:I think we've all grown tired of Sent's general pessamistic attitude in the AMD forums. Do you see us going to the Intel forum and Ranting "Intel Sucks" every chance we get?
yeah, i agree with you on that. i may like AMD better than intel, but they're not magic workers. getting 3GHz on a 4200+ on air is VERY unlikey. the 4800+ is tested higher so the cores are probly a higher quality than the 4200+. so 3GHz with a 4200+ on air, you would have to be VERY lucky IMO.{PMS}fishy said:Yeah, and you think you are going to hit 3ghz on a 4200+?
Don't hold your breath.
