- Feb 6, 2012
- Copenhagen, Denmark
Hi!
I used to play around with hardware all the time when I was a young teenager, but for the past 5 years, working as a photographer, I've owned three powerful ThinkPads and an HP EliteBook - all with 1920x1200 resolution, fast CPU etc., pretty much the most powerful laptop workstations around all costing around 4500 USD. I haven't owned a desktop in that period
But recently I've started working with HD video editing in Premiere Pro and After Effects and then I realized that a laptop just won't do when it comes to such intensive applications - so now I'm in the market for a desktop workstation costing around 9000 USD and with an expected lifespan of 3 years. Since I have changed laptop every 1½ year, if this lasts me 3 I can spend double the money. So it seems to make a lot of sense.
I already own a 30" inch 2560x1600 monitor that I will use for the new desktop, that's why I went for SLI to run anything at native resolution.
I will mainly be using it for Adobe products and in my sparetime for gaming - ofc!
I will add high-end watercooling to CPU and GFX.
By doing that I eliminate the most noisy components which is important.
Also I intend to OC the CPU, having a 3960X and running it at standard speed would be a shame I think.
So here's what I've put together so far:
MOBO: Gigabyte GA-X79-UD5
PSU: Corsair Pro Gold AX1200
CPU: Core i7 3960X
RAM: Corsair Dominator-GT 8x4 GB (32 GB) 2133 MHz CL9
GFX: 2x Asus GeForce GTX590
SYS-SSD: OCZ RevoDrive 3 X2 240 GB SSD Max IOPS (PCI-E)
CACHE-SSD: 2x Corsair Force Series GT 120 GB (RAID0 @ MOBO)
HDD: 4x WD Caviar Black 2 TB 7200RPM (RAID 0+1 @ LSI MegaRaid)
RAID: LSI MegaRAID SAS 9240-4i
SOUND: HT Omega CLARO halo XT (PCI, not PCI-E)
But I've got a few questions... that I hope you guys can help me with...
1. Instead of the GA-X79-UD5, is there another board I should consider? Since I like the idea of the Omega soundcard (for headphones) I will need 1x PCI. Also I like that the board is pretty clean, doesn't come with two tonnes of additional stuff like some "gamer"-mobos do.
2. The GA-X79-UD5 with its 8 DIMMs leaves me with a choice of 32 GB 2133 MHz RAM (Corsair Dom-GT, CL9) or 64 GB 1866 MHz (Corsair Veng, CL10) - what would I prefer?
Or with an alternative board with 4 DIMMs either 16 GB 2133 MHz or 32 GB 1866 MHz.
3. Should I add watercooling to the chipset?
4. Any other thoughts on the setup are welcome!!
Thanks
CPU: Core i7 3960X
Thanks
