Hi all,
First off all im new to this forum
A week ago I built my selfmade rig for the first time ^^
Specs:
-ASRock 880GMH/U3S3 Mobo
-AMD Phenom II 965 BE overclocked @ 4ghz(125w version)
-Ati 6870/oc
-8Gb Ram @ 1600mhz
-Zalman Cnps11x extreme cpu cooler
-Corsair TX650M PSU
Now the pc works like a charm except the fact that I did an gpu overclock from 920/1050 to 1000/1175 without any gain in fps on benchmark (ok there is some gain but its only 1 fps or so..)
I was told that this is occuring because my NB frequency is bottlenecking my GPU. My standard NB freq is 2ghz but has to be about 3 ghz (was said).
Now the problem is i don't know sh*t about NB overclocking. What is the max safe temp and NBvoltage for my mobo? AIDA64 shows me the motherboard temperature. Is this know to be the NB or could the sensor be somewhere else on the mobo?
Link to mobo specs: http://www.asrock.com/mb/overview.asp?Model=880GMH/U3S3&cat=Specifications
A little help would be much appreciated
thanks on advantage
Specs:
-Ati 6870/oc
-8Gb Ram @ 1600mhz
-Corsair TX650M PSU
thanks on advantage
