- Jul 15, 2013
ok so right now i have a computer HP Z400 LGA1366 with a xeon w3565 at stock speeds which is similar in specs to an i7 960. and im wondering i can buy a xeon W3690 which is the same as an i7 990X for around 100$ im wondering will this be a good performance increase gaming wise below is the info you may need
current specs
w3565,16 gigs ddr3 ram,sapphire platinum RX470 4GB, gaming at 1080p below is a list of the games i play
doom 4,the witcher 3,battlefield 1, call of duty WW2,GTA5
i was told i could use the intel XTU utility to easily overclock the cpu to 4GHz would i see a decent performance increase if i upgrade to the 3690 in terms of stock speed as well as if i overclock it?
cant afford a new pc build so this pc has to last me the next 4-6 years before i can afford to upgrade to a better pc
current specs
