- Jul 14, 2001
- Edmonton, Alberta
DaBigJ said:
Really? Are they significantly better than the 42.30's? If they are, I may just have to give them a try.
Well, the difference is tiny but they have fixed quite a few flaws in previous drivers such as the glitchs in Unreal2 where some portions of Wireframe showed up on the characters in some scenes.
They also boosted image quality significantly as long as you dont use aggressive performance.
Aggressive performance makes you loose image quality when your card is heavily overclocked.
OC-Master
