Goodmorning everyone.
I state that I am NOOB in terms of overclocking.
I have a problem with overclocking an Asus X-99 Pro and Corsair Dominator DDR4 3300Mhz.
If I activate the XMP profile of the 3300Mhz RAM, the pc will not start.
If you use Asus EZ Tuning Wizard (all on AUTO), the DDR4 increase from 2133Mhz to 2447Mhz with a BCLK set automatically to 102Mhz, the pc start.
I start from this point, and using Ai Tweaker, I increase the frequency of 2447Mhz RAM to a slightly higher value pre-calculated by AI tweaker (eg: 2583Mhz),the pc does not start.
What should I increase or verify to get at least 2800Mhz? The dream would be 3200Mhz.
The RAM specifications are as follows: DOMINATOR® PLATINUM 16GB (4 x 4GB) DDR4 DRAM 3300MHz C16 Memory Kit (start 2133Mhz 15-15-15-36 1.2V).
XMP 2.0 mode: 16-18-18-36 1.35V (3300Mhz).
Asus X-99 Pro can use DDR4 3300Mhz. I do not know if can reach them.
Thank you all.
Thank you all.
