I thought about doing it to my X2, but I don't think so.. I'm not going to risk $600 for a few degrees....
Running stable now at 2532mhz.. I hit 2700mhz yesterday(Saturday) but one of the cores wasn't stable.. I need to put liquid cooling back in to take care of the heat...
I got an evercool wc-202 system that I just took apart to see what tweaking can be done to it, the pump runs rather slow, and it could use with better fans.... I am going to use the HFE fluid in there and see what I can do in temps.....
I still have the DD maze4, dd12vpump, and black ice, but the maze is for socket A and I can't figure out how to get it to work on skt 939 without buying a new block..
HMM.. I wonder if I can just get the top acrylic part for it for skt 939... that is the only difference I see in the pics...
to get stable at 2532mhz, I had to bump the core up a little in voltage, 1.42now temps are close to the same at idle, only about 1c over stock, but when i run p95 on both cores it shoots up above 60c, and I don't like that...
