I had the misfortune of suffering a hard drive failure last week, on a PC well past its prime. And thus then the "fun" of impatiently trying to get smart on the latest generation of everything using nothing but my cell phone! Man, tech changes fast, hah. I've always spent months planning builds before, but this time I found myself ordering way too soon, egged on by same-day Prime shipping. In the process, I learned a few lessons that can hopefully help others.
Lesson 1: Discovered many X370 boards do NOT work with Ryzen 2xxx in practice and are not (yet) shipping with new BIOS. "Can be upgraded" is worthless if you're stuck with a board that won't POST and you have no way to upgrade the BIOS. The motherboard manufacturers are not at all clear about this on their websites which appear to have all been written before Ryzen 2nd get was released, and simply say they're compatible with Ryzen. Ugh. [This was a Gigabtye GA-AX370-Gaming, but there's similar language on other X370 boards' websites and sales listings]
Lesson 2: Picked up an X470 board, but after much frustration, I discovered I could not create a RAID larger than 2TB because my old video card didn't support UEFI, and was forcing the whole motherboard into CMS compatibility mode. I had a 4TB RAID1 running within 5 minutes of Amazon ringing my doorbell with the new video card. So, if others run into issues where they disable CMS but it turns right back on: could be an old peripheral card. If so, either need to ditch the old or live with BIOS limitations.
Lesson 3: If you're using encryption on your backups, make damned sure you back-up your encryption certificate(s), too! I got super super lucky I had a copy on an old hard drive (that lasted just long enough to export it before dying, too), but I was sweating bullets for a few days!
Specs:
Gigabyte X470 Aorus Ultra Gaming
Ryzen 2600x (w/ stock cooler)
16GB Crucial 3000GHz DDR4
MSI Radeon RX560 4GB
2x 250GB WD Blue 3D NAND SSD, RAID1
2x 4TB Seagate Barracuda 4TB, RAID1
32" & 24" 1080P monitors
Specs:
