Hey guys, I have been messing around with bios settings, trying different combinations of parameters for a while just to learn a bit about over clocking. I still consider myself to be a newb and am always looking to learn more.
After following the guide located here I have not been able to get above 3.225 Ghz without increasing voltage. When I do increase voltage the gain is minimal (.02 volts per ~2 FSB). I have included screen shots of CPU-Z (taken when bios was AUTO for RAM) and have listed my system specs below. When taken off AUTO and set to manufactures spec I fared slightly worse.
Is this a normal limit for the CPU and Voltage? Is the Voltage/FSB normal? Is my cheapo Ram the culprit? Ideally I would like to make it to 3.6Ghz. Any advice to get there? Let me know if you would like more information about anything. Thanks for your time!
Specs:
MB: ASUS M4N68T-M
CPU: AMD Athlon II X4 635 Propus 2.9GHz cooled w/ Hyper 212 +
Temps: 30 idle 42 max @ current OC
Memory: 2 X Rendition by Crucial 2GB 240-Pin DDR3 1333
Graphics: EVGA GeForce GTX 560 DS SSC 1GB 256-bit GDDR5
Specs:
MB: ASUS M4N68T-M
