I have an older x58 Rampage III Extreme http://www.asus.com/ROG_ROG/RAMPAGE_III_EXTREME/ with about 6GB of RAM in it and I want to give it an upgrade. I run several VMs at a time and I'd like to be able to give them each more memory. I also have an 1150 mobo, and if I ever chose to retire this box I'd like to use whatever memory I have purchased here as an option there.
So I'm curious what type of compatibility options I have with the newer dual channel or quad channel kits? I have 6 slots, the manual says if this:
So if I bought a Quad channel kit, would it work to fix three of them in a Triple-channel configuration?
I'd like to get up to around 12GB, but 16GB seems to be a better deal (comparing the triple channel kits still around and dual or quad channel kits). I want to be giving each of the VMs I'm running 1024-2048 comfortably, and sometimes I run up to 4 at a time.
Any help is greatly appreciated. Thanks.
4 DIMM
: Supports four (4) modules inserted into the
orange
slots (A1, B1 and C1) and the
black
slot A2 as one set of Triple-channel memory configuration
