I have this original white xbox 360 CPU cooler that I'm thinking of using as the north bridge cooler on my ASUS M5A97 LE R2.0. It's an AMD 970 chip and I don't like it running as hot as it does even though it's well within its designed range even before I added the 140mm fan to the side case.The 360 CPU cooler in question is 2.75" by 1.6" by 2.5" in size overall, with a 0.2 inch thick solid copper plate. It has a single 1/4 inch copper heat pipe soldered to the copper plate and to the bottoms and tops of the fins. It has 45 aluminum (I think, maybe something else) fins, 2 inches by 1.6 inches. Picture below. You can see the thick steel mounting clamp on the bottom but it's actually a two piece system that is screwed directly to the copper plate so those won't be a concern.
There are two things I'm not sure about. If I end up using this thing should I orient it so that the fins are vertical (relative to gravity) so that hot air will pass more easily by them? It would be right below my 240MM radiator and 2 120MM fans. Air flows very well in that direction in my case. Or, should I orient it so that the fins are perpendicular relative to gravity so that my case fans can blow air past the fins (in the direction of the rear panel of the case)? My case is set up so that the 240MM radiator is in the top panel with 2 fans, and various other 120MM and 140MM fans blow air towards the top and the back of the case.
The other thing I'm unsure about is weather or not I should/want to use thermal epoxy to permanently mount this thing, or if I want to spend the better part of a weekend disassembling my machine and tapping holes in the heat sinks copper plate and try to make it work with screws. This thing is pretty tall, as north bridge heat sinks go, and it could certainly get in the way of future upgrades and/or repairs so it would be nice if it's removable.
Thanks for reading so far if you have haha. I'm a details guy.
I've done a couple very crude initial tests on this heat sink and I have found that it is very efficient for its size. The materials, design and construction are very, very high quality. I love the idea of using sheet fins and copper plates and heat pipes as my N/B cooler. It just looks so cool!
Would you do this? Would you mount it with thermal glue, or would you spend the time and risk damaging components in order to fit it with screws? Comments?
