I am having problems with my new 6600 popping up the low power message, I have tried 3 different power supplies (SL350 and 550 antec) and the same thing. I am overclocking the CPU (2.8 oc'd to 3.08) and memory, but not the graphics card. I have tried 3 different drivers and I get the same result. I am using a P4P800 -E Deluxe MB with the 1009 bios.
Here's a couple of clips from my sandra diag: for some reason I can not determine the power seems low after trying all 3 power supplies. Any help would be appreciated and thanks.
Processor
Model : Intel(R) Pentium(R) 4 CPU 2.80GHz
Speed : 3.08GHz
Performance Rating : PR4096 (estimated)
Cores per Processor : 1 Unit(s)
Threads per Core : 2 Unit(s)
Package : FC µPGA478
Rated Speed/FSB : 2800MHz / 4x 200MHz
Multiplier : 14/1x
Minimum/Maximum Multiplier : 0/1x / 14/1x
Generation : G8
Name : P4P (Prescott) Pentium 4E 90nm 2.8-3.8GHz 1.25-1.40V
Revision/Stepping : 3 / 3 (0)
Stepping Mask : C0
Microcode : MU0F330C
Core Voltage Rating : 1.400V
Maximum Physical / Virtual Addressing : 40-bit / 32-bit
Native Page Size : 4kB
Part Number : To Be Filled By O.E.M.
Asset Tag : To Be Filled By O.E.M.
Serial Number : To Be Filled By O.E.M.
Co-Processor (FPU)
Type : Built-in
Processor Cache(s)
Internal Data Cache : 16kB Synchronous, Write-Thru, 8-way set, 64 byte line size, 2 threads sharing
Internal Trace Cache : 12kB Synchronous, Write-Thru, 8-way set, 64 byte line size
L2 On-board Cache : 1MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector, 2 threads sharing
L2 Cache Multiplier : 1/1x (3080MHz)
Upgradeability
Socket/Slot : CPU 1
Upgrade Interface : Socket 478
Supported Speed(s) : 3.60GHz+
Environment Monitor 1
Model : Winbond W83627(T)HF ISA
Version : 9.00
Mainboard Specific Support : No
Power Rating(s)
CPU Core Power : 86W (estimated)
CPU Cooling System Thermal Resistance : 0.12°C/W (estimated)
Sensors
CPU Temperature : 37.5°C / 99.5°F td
Auto Fan Speed Control : No
CPU Fan Speed : 2109rpm
CPU Voltage : 1.34V
Cooling Device(s)
Chassis Fan Speed : 2235rpm
Power / Aux Fan Speed : 1696rpm
Voltage Sensor(s)
CPU Voltage : 1.38V
Aux Voltage : 3.06V
+3.3V Voltage : 2.94V
+5V Voltage : 4.60V
+12V Voltage : 10.52V
-12V Voltage : -14.91V
-5V Voltage : -7.71V
Standby Voltage : 4.61V
Here is my DXdiag:
System Information
Time of this report: 10/9/2005, 09:28:48
Machine name: ENCHANTICA1
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 08/04/05 18:00:14 Ver: 08.00.09
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 234MB used, 2228MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6600
Manufacturer: NVIDIA
Chip type: GeForce 6600
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_00F2&SUBSYS_211C1682&REV_A2
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.7801 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/2/2005 16:35:00, 3908864 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 8/2/2005 16:35:00, 3198560 bytes
Device Identifier: {D7B71E3E-43B2-11CF-4B6B-160103C2CB35}
Vendor ID: 0x10DE
Device ID: 0x00F2
SubSys ID: 0x211C1682
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_812A1043&REV_02
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5440 (English)
WHQL Logo'd: Yes
Date and Size: 1/9/2004 10:17:02, 601100 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SoundMAX WDM MIDI [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Compaq USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x049F, 0x0051
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 01:08:42, 57600 bytes
| Driver: usbd.sys, 8/23/2001 07:00:00, 4736 bytes
+-+ USB Human Interface Device
| | Vendor/Product ID: 0x046D, 0xC508
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidclass.sys, 8/4/2004 01:08:19, 36224 bytes
| | Driver: hidparse.sys, 8/4/2004 01:08:16, 24960 bytes
| | Driver: hid.dll, 8/4/2004 02:56:42, 20992 bytes
| | Driver: hidusb.sys, 8/23/2001 07:00:00, 9600 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 8/4/2004 00:58:32, 23040 bytes
| | | Driver: mouhid.sys, 8/23/2001 07:00:00, 12160 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 00:58:34, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 00:58:32, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 03:01:07, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 13.1 GB
Total Space: 20.0 GB
File System: NTFS
Model: SAMSUNG SP0802N
Drive: D:
Free Space: 8.1 GB
File System: NTFS
Drive: E:
Free Space: 33.1 GB
Total Space: 36.3 GB
File System: NTFS
Drive: H:
Model: CDWRITER IDE5232
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:52, 49536 bytes
Drive: I:
Model: SONY DVD-ROM DDU1621
System Devices
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Device ID: PCI\VEN_8086&DEV_2571&SUBSYS_00000000&REV_02\3&267A616A&0&08
Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/4/2004 01:07:41, 42368 bytes
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Device ID: PCI\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\3&267A616A&0&00
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_80A61043&REV_02\3&267A616A&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:37, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:42, 57600 bytes
Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_80A61043&REV_02\3&267A616A&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:37, 26624 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:42, 7168 bytes
Name: Intel(R) 82801EB Ultra ATA Storage Controllers
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_80A61043&REV_02\3&267A616A&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:41, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:42, 95360 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_80A61043&REV_02\3&267A616A&0&EA
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_8086&DEV_24D5&SUBSYS_812A1043&REV_02\3&267A616A&0&FD
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 01:56:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 01:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 00:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 00:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 00:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 00:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 01:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.5440 (English), 1/9/2004 10:17:02, 601100 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0022 (English), 1/8/2004 13:54:06, 65536 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0017 (English), 1/8/2004 13:53:58, 14204416 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 00:54:58, 141016 bytes
Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0009 (English), 1/8/2004 13:53:54, 5672960 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXSENS.SYS, 5.10.0000.3511 (English), 12/11/2003 10:54:14, 391424 bytes
Driver: C:\WINDOWS\system\crlds3d.dll, 4.12.0001.2002 (English), 11/21/2002 02:07:10, 765952 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 4.12.0001.2008 (English), 9/19/2001 08:32:26, 720896 bytes
Driver: C:\WINDOWS\system32\Audio3D.dll, 4.12.0001.2009 (English), 8/19/2003 06:36:16, 65536 bytes
Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0000.0001 (English), 12/17/2003 13:05:50, 155648 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_80A61043&REV_02\3&267A616A&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_80A61043&REV_02\3&267A616A&0&FB
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_80A61043&REV_02\3&267A616A&0&E8
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&267A616A&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Intel(R) 82801EB PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&267A616A&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:46, 68224 bytes
Name: Marvell Yukon Gigabit Ethernet 10/100/1000Base-T Adapter, Copper RJ-45
Device ID: PCI\VEN_11AB&DEV_4320&SUBSYS_811A1043&REV_13\4&2E98101C&0&28F0
Driver: C:\WINDOWS\system32\DRIVERS\yukonwxp.sys, 6.28.0000.0000 (English), 10/23/2003 07:28:00, 174336 bytes
Driver: C:\WINDOWS\system32\wbem\mof\gewmi.mof, , 0 bytes
Driver: C:\WINDOWS\system32\mrvdlg.dll, 1.00.0000.0001 (English), 10/23/2003 12:59:56, 12288 bytes
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_808A1043&REV_80\4&2E98101C&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:10:08, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 01:10:06, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:58:29, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:58:29, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: NVIDIA GeForce 6600
Device ID: PCI\VEN_10DE&DEV_00F2&SUBSYS_211C1682&REV_A2\4&38B71F77&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.7801 (English), 8/2/2005 16:35:00, 3198560 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.7801 (English), 8/2/2005 16:35:00, 127043 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0024 (English), 8/2/2005 16:35:00, 32768 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0024 (English), 8/2/2005 16:35:00, 32768 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.7801 (English), 8/2/2005 16:35:00, 3908864 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.7801 (), 8/2/2005 16:35:00, 540672 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.7801 (English), 8/2/2005 16:35:00, 5140480 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.7801 (English), 8/2/2005 16:35:00, 7110656 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.7801 (English), 8/2/2005 16:35:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.7801 (English), 8/2/2005 16:35:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.10532 (English), 8/2/2005 16:35:00, 286720 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 8/2/2005 16:35:00, 168844 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 8/2/2005 16:35:00, 55444 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:41 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:41 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:41 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:41 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:03 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:03 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 82432 bytes
system.dll: 1.01.4322.0573 English Final Retail 12/31/2004 09:12:50 1216512 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 07:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 02:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 02:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:41 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 02:56:42 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:57 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/4/2004 02:56:44 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:24 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 02:56:45 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 02:56:57 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 02:56:57 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 02:56:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 02:56:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 02:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 02:56:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 02:56:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 02:56:57 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/4/2004 00:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:41 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:38 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:12 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:57 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:57 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:57 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:12 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:12 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:12 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:43 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:16 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:28 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:16 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 02:56:46 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:21 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:46 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:09:58 51328 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.2600.2180
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Analog Devices Kernel wavetable Synth,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
SoundMAX WDM MIDI,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
Realtek AC97 Audio,0x00000000,0,0,,
WDM Streaming Rendering Devices:
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
WDM Streaming Communication Transforms:
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
Realtek AC97 Audio,0x00200000,17,2,,5.03.2600.2180
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
Processor
Speed : 3.08GHz
Multiplier : 14/1x
Generation : G8
Stepping Mask : C0
Co-Processor (FPU)
Type : Built-in
Processor Cache(s)
Upgradeability
Socket/Slot : CPU 1
Version : 9.00
Power Rating(s)
Sensors
CPU Voltage : 1.34V
Cooling Device(s)
Voltage Sensor(s)
CPU Voltage : 1.38V
Aux Voltage : 3.06V
+5V Voltage : 4.60V
Here is my DXdiag:
System Information
Memory: 1024MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x00F2
Revision ID: 0x00A2
Revision ID: 0x00A2
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
| | Service: HidUsb
| | | Service: mouhid
Gameport Devices
PS/2 Devices
| Service: kbdhid
| Service: TermDD
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 13.1 GB
File System: NTFS
Drive: D:
Free Space: 8.1 GB
File System: NTFS
Drive: E:
Free Space: 33.1 GB
File System: NTFS
Drive: H:
Drive: I:
System Devices
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
