- Aug 27, 2003
- Mississauga, Ontario
So, this is not as easy as I thought. I don't see any XMP on the AI Tweaker on my Asus x570 Prime-Pro mobo. My 3200Mhz LPX Vengeance runs at 2100mhz (1066 in cpu-z, which shows the XMP profile for 3200mhz as an option).
After a while, I did put in the numbers manually, I am now running at 16-18-18-38 3200mhz (cpu-z shows half that, that's normal right?), but really, who is to know if that is correct? I just found these numbers on the web somewhere, and in fact that article wanted me to change ALL the numbers from auto, I only changed the main 5 tho.
Is there a way to run the advertised exact numbers through XMP, or a place where I can see the best numbers for x570 for 3200mhz cl16 ram?
Thanx.
Thanx.
