- Jun 8, 2012
- Chicago, IL
I came across a Dell OptiPlex 960 SFF desktop and turned it into an HTPC. Bought a video card and the Asus Xonar DG for the 5.1 audio and S/PDIF output. I unfortunately didn't research this card well enough because it apparently only supports 2-channel PCM via the S/PDIF output.
The OP960's audio will be going to my AV receiver w/ 5.1 channel surround which has 7 speakers and a subwoofer. The desktop is used for playing recorded HD TV, music, videos, and movies via my main desktop through XBMC/WMC mostly, and it is also configured to use one of the tuners from my Ceton InfiniTV 4. Now for my question(s)...
My AV receiver does have a multi-channel input. I would just need to buy 3.5mm to RCA converters in order to make the connections. Should I go this route, or return the Xonar and get a card that can properly send Dolby Digital 5.1 through the S/PDIF output? If the I go the multi-channel input, am I going to lose any sound quality? I'm not at all an "audiophile", but I would like some good sound and 5.1 surround. If a "proper" card is suggested, could I get a recommendation? I'm not too interested at spending $100+ on a sound card. I was just hoping to have a decent HTPC to play my files over HDMI and 5.1 audio, not at all a looking for a top of the line PC.
Thanks for any help that you guys can offer.
