- Feb 20, 2003
- australia
ok first of all here is my system
System
athlon XP 1800+ (palimino AGOIA 0226) @ 1773, 2.00 volts
Epox 8K9AI -KT400 - AGP 8x
2x256DDR PC 2100 @ 380 MHZ
MSI MS-8894-70 TI4200 128mb 8x @ 300/600mhz
Western Digital Cavier 40gb with 8mb cache
diamond data 40x32x10
hitachi 16x DVD
Cooling
copper heatink with 5000 RPM fan
4 case fans @ 6000 RPM
3Dmark 2001 SE 12249
3Dmark 2003 1506
now my problem is i cant get my clock speed higher than 1773mhz with stability. ive had 1810mhz but windows crashes within 5 minutes.. y? i have seen other systems only with exact same CPU and mobo with locked multiplier reach 2.1ghz and apparently they have stabilty (yes i know they could be lieing) i know its not a matter of heat cause my system never gos over 50. is there some other settings in bios i need to change.. do i need better ram? is my video card not able to handle a higher bus speed? do i need more voltage? i have my voltage at 2.00 which is the most i can get out of my mobo.. ne help or ideas would be great or point me in the direction of some help...
cheers
System
hitachi 16x DVD
Cooling
3Dmark 2003 1506
cheers
