- Nov 24, 2005
- San Antonio, TX
- Thread Starter
- #21
The molex powered splitter was the one that was going to the CPU PWM header and was being controlled properly the SATA powered splitter was plugged into the Sys1 header and running at 100% even though it was set at 50% in the BIOS and in the Control Center software.
This is what I have tried since I got home:
-swapped splitters between headers both splitters work properly on the CPU header and neither worked correctly on the Sys1 header
-plugged a Corsair SP120 Performance PWM fan into both headers and it worked correctly on both
-plugged MCP35X pump into both headers and it was only controllable on the CPU header on Sys1 it would just run at 100%
