maximum with a separate compartment: I will gut out all the insides use only the shell and the front door with dials section and create a faux kitchen counter top and drawer for the psu hard disks and other drives. If i get matx i will probably put most of that stuff in the non-food compartment part and itx i will buy a busted bitfenix itx case... OH I am buying some busted bitfenix cases to use for the mobo tray or vga support btw.. I can't believe I forgot to mention that.basically I have a toaster oven its like a mini oven.
and 5ghz is high closer to 4.8 oor 4.7 24/7 during optimal conditions
I am gonna have enough room to put atleast a 240 radiator in it i figure minimum space i have is (W11"xD10" ) and H7 inches tall max is W14"xD10.5' If i want to be bare wit it I can just use its shell and basically use it like a box with the opening on the bottom and lower it over components On a bench table
dimastech in the mail isn't related to this build I am just using the cpu and mobo as a spare part while my 3930k rampage 4 extreme is in for RMA so that is in there to add reference for the time I need the mobo/cpu by
So what the is so difficult or banworthy about my simple, relevant motherboard question that I posed in the self explanitory intel mtherboard forum thread with the thread title z87 narrowing down the chipset. I am looking for a z87 motherboard worthy of cramming into my deathtoaster.
How is it my fault you are too dense to suggest some motherboards or too anally retentive to laugh at the proposition. I baited you guys to ask me what I meant because these go on for pages any ways it's meant to intrigue then scroll down and grab your attention... its a toaster build! lighten up... If you guys don't wanna see a toaster build then I will go to a different forum where the trolls aren't screamming troll
