- Apr 26, 2002
- nm
Larva's first post criticizing the review of this zalman duct setup contained useful criticism, which I found to be constructive.
These are public forums, and nobody owns a thread. there is no such thing as MY or YOUR thread.
Larva pointed out that in a cooler case, the zalman won't outperform or perform on par with the aeroflow.
52C is a very high case temperature. Many of us here would indeed encourage you to seek better case ventilation to bring that temperature down, regardless of what case you're using.
Many of us would still encourage you to seek better case ventilation to bring that temperature down, regardless of what HSF you're using.
Larva wrote:
That's pretty much what your tests revealed: That the zalman performed best when it was directly ventilating the hot cpu air to the case exhaust...aka crutching the case ventilation...if the case was ventilated more efficiently, a the duct wouldn't make any difference.
It definitely looks like the zalman helps in poorly ventilated cases.
another thing that helps in poorly ventilated cases is improved ventilation by adding more and/or better fans.
in a well ventilated case, those other heatsinks you mentioned will probably outperform that zalman.
maybe you didn't like HOW larva said his piece, but if you read larva's piece for WHAT it says, WHAT it says is accurate.
Sit back and laugh it off dude. Don't take things so personally.
Larva is kinda fun to watch.
Get over it, he caught you with your "fans down".
~BdK
Larva wrote:
it does its best when using its fan to crutch the case ventilation rather than blow on the heatsink
~BdK
