If you're going to continue pushing the CPU you shouldn't push the RAM at all, which means dropping it to the lower speed with the same timings you have now.Should I up my CPU-NB more? Will it give me a better performance? I know in Dolk's write up he said around 2400-2600MHz for my CPU speeds, but he wasn't writing about the Thurban. Does it still apply? The faster the cpuNB runs the better your memory performance.
What settings should I change to go for 4GHz?
For my RAM, should I try setting it to 667MHz or should I leave it at 533MHz and try to tighten up the timings?
