Well I recieved my new amd xp2100+ B and the new cpu cooler. I played with it a bit over the weekend after burning it in.
My 1st couple attempts ended up with a no-boot or lack of stability when running Prime 95.
So I started slowely:
Seems I can not get my FSB over 147. So I backed it down to 145 and uped the Multiplier to 14 = 2030mhz
I have not adjusted Voltage, still at 1.6
Ran Prime95 over night and another CPU burn prog(can't remember name) for approx 6hrs with no problems.
Temps:
MB: 27 idle 28Load
CPU: 31-33 idle 35-37 load(usually 35)
Here is my set up:
AMD XP 2100+ B
Asus A7N8X DELUXE
512mb Excelerate PC2100 DDR 266
2-128mb pc2100 ddr 266
Visiontek NVidia Geforce 3 ti500 64mb DDR
Here are my questions:
1) Is this pretty good?
2) Should I try and up the multiplier more?
3) Do you think it is the memory that is holding back the FSB?
a) If yes, what could I expect if I put in 2-512mb PC2700 cl2?
4) When or how do I know if I need to change my voltage?
Thanks for helping out a beginner!
Eric
Temps:
MB: 27 idle 28Load
Here is my set up:
AMD XP 2100+ B
Asus A7N8X DELUXE
Eric
