bass said:Yes it's stable...... The cpu is a XP2500M IQYHA0408RPMW on a Abit NF-7s(unmodded) oh and as for ram I've kingston bh5.It's cooled by a Mach 2 GT, I'll run more benches a little later and post back the results
9mmCensor said:
Crank that FSB... !
OC Detective said:So you have BH5 yet you are not upping the FSB - why? BTW how do you know if it is BH5?
jAY said:FSB bus, FSB...
When gona drop the multiplier and crank that????
oc_byagi said:I think it's just an artifact under "instruction" field, at least it's a possibility. I don't think anyone who even bother photoshopping would leave something that obvious left on their pic. I'm sure it's barely running at that speed tho, should run around 2.9ghz with stability.
Also notice "unknown CPU 'typ,'" wrong output from unstability?
Unknown CPU Type is a result of the motherboard not knowing what the chip is. An example of this is running a Mobile chip on a normal motherboard. Mine used to show unknown cpu type until I updated my bios. Now it shows "Duron" because my L2 cache is ****ed (L2 reports only 64k instead of the 256k.. bunk chip).
