My radiator has 5/8" OD barbs. I have 7/16" ID masterkleer tubing and i can't seem to get it over the barbs. What's the best way to do this, i already tried soaking it in warm water?
My radiator has 5/8" OD barbs. I have 7/6" ID masterkleer tubing and i can't seem to get it over the barbs. What's the best way to do this, i already tried soaking it in warm water?
depending on the brand you may or may not be able to d it. you can stretch it with some brands by heating it in boiling water but be aware the more it stretches the higher the possiblility of splitting
if its the masterkleer stuff, you'll probably need to put it in some hot water and/or put soap on the end of the barb to get it over it without too much of a struggle, but you'll be able to make it fit - its only 1/16" smaller than 1/2" ID tubing
